QR25DE »
https://forums.nicoclub.com/qr25de-u131839.html
Sun Dec 19, 2010 5:55 pm
1. Learn how to spell transmission.
2. Save up 4500 dollars. (This is a bit over kill, however, if you run into problems you have backup funds).
3. Find the following:
a. a donor car or all the manual trans gear which involves the following:
1. Manual transmission.
2. Clutch and brake pedals.
3. Shifter and shifter linkage and/or cables.
4. Mounts of the transmission mounts are different.
5. A new clutch, you'll want to replace this while it's apart.
That covers the basics.
You will need to cut holes etc for the clutch and brake pedals and mount them accordingly.
Laborr alone will be a killer if you're not doing it yourself.
Honestly, it'd be cheaper to buy a MTX 2005 Altima.
