transmisson problem??
I_eat_hondas
Car: my car and my new baby boy Caleb
I recently completed my sr swap(s13black top->s13 hatch) the problem is this, when I am in gear, and step on the throttle the car goes like a mofo till about 3500 rpm then it seems like its in neutral. Almost like the clutch is slipping. If I feather the gas it seems to go away, what would cause this? I am running the stock clutch. Antother thing is it seems like my bov opens way before I let of the throttle. It sounds like it is blowing off even when I am still on the gas. I am running a PROF BOV. I know these two questions are not really related but why make 2 posts!! any help would be great!!
I_eat_hondas
SOMEONE PLEASE HELP!!!!!!!!!!!!!!!
240_Keyy
Car: '90 240 Fastback
it actually sounds just like you said, your clutch is slipping. Did you put in a new stock clutch or are you running on the one that came with it?
3500 is right about where you will start making lots of TQ in the SR, mine did the same thing on the stock clutch. An ACT unsprung 6-puck will solve that problem right up for ya :D
I_eat_hondas
thanks, any other advice?? What do I use for a stock clutch, this project has just about bankrupt me...lol so I need a cheap way out of it and maybe a stock clutch will be cheaper than a aftermarket one...I doubt it, but maybe
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
ill sell you the stock one,on my s13 sr20,let me know.
I_eat_hondas
how many KM on it and how much you want
9240sx
my clip had 43,000 km on it.so the clutch sould have the same.And I have not drove the car yet.throw me a good offer.
JJ240
Car: 95 white 240
you can use an OEM maxima clutch from early 90s maximas. Its like $115 or so for a clutch kit with throwout bearing, clutch, and pressure plate.
JJ240
Car: 95 white 240
also be sure to resurface your flywheel or youll be in the same boat again in a month.
240_Keyy
yeah do what JJ240 said
OR is you want to spend a total of about $200 you could do like me and get a stock early-90's maxima pressure plate, an act unsprung 6-puck, and a throw out bearing and have a super grippy clutch with EASY engagement...
I_eat_hondas
OK Im thinking that maybe my clutch isnt shot. I think it just needs some major adjustment. it dosent engage untill the pedal is all the way out. how would I go about adjusting the clutch
JJ240
Car: 95 white 240
You want the clutch to engage at the top of its throw. If it engages lower it means you need to bleed your line or replace your slave cylinder.
RobDET
Car: Cars
I like the clutch to engage right in the middle. There is thread on the rod that hooks to the clutch pedal. You can adjust there. It sounds like you may have a big boost leak. That would kill the power when the boost got high and would sound like a leaky BOV
I_eat_hondas
So Rob, how would I go about detecting a boost leak? I mean besides checking all thee vac lines and what not
240_Keyy
well you should pull between 16 and 22 mm/hg at idle. Anything less than that and you probably have a leak
RobDET
Car: Cars
Vacuum at idle will not show a boost leak in the intercooler piping. You have to follow the high pressure path from the turbo to the throttle body. If that's all tight and sealed then you should be OK. Sometimes something can be leaking that is very difficult to see. revv the motor a bit with the throttle body by hand and feel for air along the intercooler piping.
I_eat_hondas
240_Keyy wrote:well you should pull between 16 and 22 mm/hg at idle. Anything less than that and you probably have a leak
I am running about 20 I am beginning to think it is the clutch and I really dont feel like fixing the clutch I hate cars...oh wait a minute, no I dont
