transmisson problem help
davesg35coupe
Car: 2003 g35 coupe,2003 passat,2006 slk 55 amg
ok my car just had a new clutch put in 4K ago and no the car does not move i replaced the slave and master cylinder. I have to press the clutch to put the car in gear but when in gear the clutch does not have to be pressed in and the car does not die my problem is i don't know what to replace next since the car will not move and the car is out of warranty..
infinititech1
does it do it in all gears? you need to have someone push the clutch pedal and you need to look under the car and see if the slave cylinder is pushing the fork. if it is...then you have a problem with either clutch pressure plate assymbly or internal transmission
davesg35coupe
yeah does it in all gears p.s how far is the slave cylinder suppose to push the fork
