Structure240sx »
https://forums.nicoclub.com/structure240sx-u1949.html
Mon May 09, 2005 8:19 pm
i hear you can use an sr transmission if you put a ka bell housing on it. im kidna sketchy if the speed sensor will work tho. if the sr does then the rb20 will/should not sure after that. those 3 are the same not benefit over the other except the ka has a better 5th gear
