GseaQ »
https://forums.nicoclub.com/gseaq-u329.html
Mon Mar 10, 2008 10:34 pm
Chris, the leather and interior is in very good to excellent condition. The back seat is literally in new condition. I don't think the 2 previous owners had young kids. The leather in front is very good. It has only been treated 2 or 3 times in the 7 years we've had it and shows some wrinkles, but no cracks through the seat covers. The carpet is excellent.
The steering rack has a leak, but it doesn't seem to be the shaft seals, but rather around the solenoid. I've put some Lucas Power Steering sealer stuff in it and it seems to have helped.
A lot of the light bulbs for the white lettering on the switches are burnt out. I don't think those bulbs can be replaced, so I bought most of the switches from another NICO member to swap, but never got around to it. They'll go with the car. All the other lights in the car work properly - even the "Low Fuel" message started working for the first time ever with the latest fuel pump installation.
I think the R134a refrigerant/oil needs to be topped up. The compressor I had put in last year makes a little noise sometimes after engine start-up, but it's really only noticeable at idle. It still blows cold. Of course I only paid $85 for the rebuilt compressor, so if I had to pay it again, I would and not complain.
Here's the write-up for the For Sale, but it's not listed, yet. BTW, our gallons are bigger than yours so take 1 mpg off what I said.
"4.5 Litre 278 HP V8, 4 speed automatic, Traction Control, ABS, 23 mpg (hwy) & 20 mpg (combined city/hwy). One of the BEST maintained Q45's in Canada with all Synthetic fluids changed/flushed regularly for the last 7 years. Maintenance done by Orlado Auto Service. In excellent condition for it’s age and very good condition for a car of any age.
Updates include metal-backed timing chain guides, rear stabilizer bar, 1995 transmission with 1st gear start Transmission Control Unit, B&M External Transmission Cooler, 16” Eagle Alloy wheels for summer high performance tires (245/50ZR16) (currently on original wheels with Michelin Pilot Alpin snow tires), Bronze 35% tint & Alpine AM/FM Single CD stereo.
New fuel pump & knock sensors in 2008; battery, A/C compressor, front/rear brake pads, antenna mast & wiper blades in 2007; spark plugs (due again next year), radiator, steering rack boots, front/rear Tokico shocks, master cylinder, Daytime Running Light module, #1 fuel injector & coil, alternator and under plenum hoses in 2005; timing chain guides (old ones were still in good shape) & oil pump drive chain/sprockets and coolant pipe cap in 2003; rear transmission mount, thermostat & TCS relays in 2002; front sway bar bushings, front upper links, #3 fuel injector, oxygen sensors & under plenum hoses in 2001.
This car is highway driven daily. It has 315,000 kms (195,600 miles) and is completely reliable, quiet, smooth & comfortable. It has the styling of a Jaguar, the performance of a BMW and solid Japanese reliability. It has always passed Air-Care tests the FIRST time and with clean numbers."
Modified by GseaQ at 1:48 AM 3/11/2008
