ArmedAviator »
https://forums.nicoclub.com/armedaviator-u262955.html
Tue Jul 26, 2016 6:08 am
There are magnets in the bottom of the pan. Usual wear materials are collected by them.
My guess is ATF starvation because of low fluid and as it heats up and expands, you just barely have enough. This is BAAAAD. If clutches are engaging with light pressure than the lose clutches are being burnt up. They will be burnt up in minutes like that.
Check fluid level first. Remember to check it when at normal temp and on a level service in park. Run the transmission through all gears and then check. If not in the proper marks, fill to correct point (1/8 quart at a time).
If your fluid level is correct, then my next guess is a bad solenoid that is sticking when cold.
