Need4Speed »
https://forums.nicoclub.com/need4speed-u3953.html
Tue May 11, 2004 4:44 pm
Our Subject:
1993 Q45 std.182,000 miles. (I have owned since 177,000 miles)transmission flushed last year approx. 5000 miles ago.transmission pan drop w/ screen and fluid change approx. 1000 miles ago.No aux transmission cooler (I am in NW lower Michigan with summer high temp of 80 deg.)transmission fluid at pan drop was nice color and screen was clean.transmission fluid at this drop was slightly burnt and dark red with some very fine grey material in bottom (2-3 table spoons worth)
Symptoms:
1 to 2 shifts fine will not shift to 3 (as far as I can tell...RPM stay same)when in D will not shift to 3 or 4 from 2
transmission up until this point has been good, with nice shifts and no slipping.
Self diagnostic initially gave me code of 3 (throttle position sensor circut).However, I checked connector, cleaned and lubed connector and error went away.
Is she terminal? Should I try another flush? Do I just need to start shopping for a new (used) transmission as I can not afford a factory rebuilt at this time.
Thanks for your input,
Andy
