Transmission wiring
vocationalzero
Car: 92 Too For Dee
87 BMW 635 CSi
06 Dodge Dakota Night Runner Edition
06 Nissan Sentra S
I looked and searched and i can't figure it out. How do I connect the SR trans. harness to the rest of the car and make it fit? As in, what connectors do I need off the KA harness to make it work. I looked at the two side by side and neither seem like they will match up. This is all I really need to make the car start up. Any help is appreciated. FRsports.com does not have anything neither does heavythrottle.com
vocationalzero
Car: 92 Too For Dee
87 BMW 635 CSi
06 Nissan Sentra S
Anybody any help?
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
I personally used all the sensors out of my KA along with the ka lower harness, you will have to make the altenator connector a little wider to fit on the altenator
vocationalzero
Car: 92 Too For Dee
87 BMW 635 CSi
06 Nissan Sentra S
will the ka harness plug into the sr sensors or should i use the sr sensors?
240life
The speed sensor should work on 92 and up models, but your transmission could have been replaced. All the KA sensors will bolt onto the SR transmission. Then you just lay the KA harness across the transmission and plug in the available sensors. My SR transmission had one less sensor, so I left that plug hanging.
vocationalzero
Car: 92 Too For Dee
87 BMW 635 CSi
06 Nissan Sentra S
Oh ok, thank you.
Silvia007
Car: 93 Nissan 240SX SE Fastback
Pull the two sensors that are on the KA trans that corresponds to the two on the SR's trans. Put the KA sensors in the SR and plug in the two that fits and you'll be fine. The other two plugs that go into the trans you can just leave hanging. I'd tape them up though. As for the speed sensor, be sure to pull the one off your KA and put it in the SR.
One more thing, you can use your KA lower harness.
shift_SRDETuser
Car: 1996 Nissan 240SX SE
Silvia007 wrote:Pull the two sensors that are on the KA trans that corresponds to the two on the SR's trans. Put the KA sensors in the SR and plug in the two that fits and you'll be fine. The other two plugs that go into the trans you can just leave hanging. I'd tape them up though. As for the speed sensor, be sure to pull the one off your KA and put it in the SR.
what if you ka is an automatic transmission?
240life
get a manual transmission
shift_SRDETuser
240life wrote:get a manual transmission
Ok the transmission for my SR is a 5 speed. I have already bought the USDM 5 speed sensor. The only question is will the SR transmission have the reverse light sensor and the neutral position switch on it and will it work with the lower KA harness?
vocationalzero
Car: 92 Too For Dee
87 BMW 635 CSi
06 Nissan Sentra S
Yeah, I already switched the speedo sensors off of my KA transmission, I just didn't know what else I needed/should do cause this is all that's stop[ping me from getting this thing running. If anything pictures could help on which sensors I should connect and which ones to leave hanging if that's possible and not any trouble.I appreciate all the help NICOmembers have given me.NICO FTMFW!!!
