Justin35ll »
https://forums.nicoclub.com/justin35ll-u118020.html
Mon Mar 02, 2009 9:41 am
well if its connected then first thing you should check is the fuse under your dash. I think its the 10amp on the bottom right of the fuse panel.
If it's not blown then check the wiring with a multimeter to see if you have an open somewhere
