Transmission wire harness sensors stuck
l7ck77
Car: 1991 Nissan 240SX
Im not sure if thats what you call them, but im taking my transmission out and I cant get the the sensors that are connected to wire harness with the clips on them, they are stuck bad, I got one out but the rest are fighting car is a ka24de these sensors with clips have never been taken off before
PapaSmurf2k3
Site Admin
Yeah those buggers can be tough. Sometimes spraying them with WD40 will help... you might have to do a few applications/let it soak a bit.
l7ck77
Thank you, I ended up getting them out, just needed a flat head and kind of wedge it and twist the flat head to get it to break free
PapaSmurf2k3
Site Admin
Glad it worked. Sometimes that can damage them a bit, but even then, its better to damage the connector a bit than to not be able to get it off entirely. Good luck with the rest of the labor!
