hksdrift240 »
https://forums.nicoclub.com/hksdrift240-u143017.html
Sat Sep 12, 2009 12:11 pm
I got a 95 240 5spd. manual with 164k miles on it a few days ago and something in the transmission area is whining. I checked the oil level in it yesterday, and it didn't have any, or was really low, so i filled it all the way back up and drove it today but something is still whining. Im thinking its the thowout bearing because it whines with the car in neutral and reving it up, but as soon as you press the clutch in, the whine goes away...it also makes a rumble like noise idling, but again, it goes away when the clutch is pressed. Once in gear and moving, the whine changes pitch with rpm change. The only thing I dont understand is that it whines in every gear including reverse except for 4th gear, which makes me think its a throwout bearing and something else. The guy said it had a ACT clutch kit put in it maybe 4k miles ago.
