forecast »
https://forums.nicoclub.com/forecast-u7026.html
Thu Jun 12, 2003 2:51 am
the tranmission computer monitors a number of sensors (engine speed, toque convertor speed, throtle position, vehicle speed, gear selector position), talks to the engine computer, as well operates a number of solenoids in the transmission, it measures the current flowing through the solenoids to enusure that at least electrically they are functioning correctly.
The transmission computer flashes the malfunction notice when one of the sensors produces a value that doens't computer or when a solenoid's ohm reading goes out of normal (shorted or open)
There is a simple one minute method to ask the transmission computer what it's complaning about. Use the service manual bible that came with the car. If you can't find it, report back and I'll type you through it.
