This was something I answered on removing the an autotranny and needing more room, the same goes for the manual transmission. Nick574-240sx wrote:disconnect the drive shaft and crossmember. Yes i ment jack the rear of the transmission up till it stops. It will tilt the engine away from the firewall so you have more room to get to the the 3 bolts at the top of the transmission and the starter bolts on the auto you are pulling out. Or you could do it the hard way and use 5 feet of extentions and universal knuckels. Nick
