While this is better than doing nothing, it still leaves 60% of the contaminated ATF in the TC and planetary gears. A true mechanical exchange is indicated with a pan drop, filter, gasket, O ring and one time bolt replacement. Look for a BG shop (www.bgfindashop.com) or a SnapOn garage with the Sun machine, which will also remove the PS fluid as well if it is not brown.Infinitiguy19 wrote:I plan on doing a drain and refill on my Q45's Automatic Transmission every time I do a engine oil change. I change my Q45's engine oil every 3K miles. In a year or so I plan on doing a Manual Transmission swap.
