silver2k2 »
https://forums.nicoclub.com/silver2k2-u57091.html
Mon Jul 09, 2007 9:35 am
Good point I guess you really want to know what the temperature is coming out of the transmission. The ideally measure again to see the temperature coming out of cooler.
I will plan on putting it on the line from AT to the cooler and measure temps.
I like the manifold idea becuase I can take it out later. As opposed to tapping the pan I dont plan on keeping it long term, as I dont really see a good place for it.
My transmission has a 120k on it with 2 dealer flushes and 1 BG flush documented, so now its ready for its third.
I would like to combine the addition of the transmission cooler with the fluid change when I do it but would like to see if the transmission cooler is needed if the fluid is just changed every 30k. As far as I can see everyone just says add it, but no before after temps to show it was needed in the first place.
We have see the increase in line pressures we cause by adding the cooler, however we dont know if that has any negative results.
The way I see it if it isnt broke dont fix it, if temps stay low enough with the factory cooler, then why add extra line pressure.
I guess it depends on where you live and what kinds of driving you do. Thats why I would like to monitor myself.
Can the internal sensor be easily read, I know the USB Consult wont do it
Modified by silver2k2 at 1:18 PM 7/9/2007
