first things first pull the ecu codes and go from there...my first J did the same thing right after i had the transmission rebuilt...pulled the codes only to find out it was the knock sensor and an injector...pull the4 ecu codes to rule out possibilities because at this point ti could be anythingunlimited wrote:maybe? i think i'm having a problem... whenever i'm at a stop light and it turns green i press down on the pedal a little and the car really doesn't push off and when it shifts to the next gear it will jerk the car back and then revs and feels like its shifts again when it already had half a second before. so to avoid that motion i always push it down about half way to take off and it will shift pretty smoothly and i'm pretty much ahead of all the cars by then and then when it shifts a 2nd time it will drag back which makes me have to press down more to get it going faster or keep the acceleration steady. all of the pressing down usually causes me to go over the speed limit and waste a lot of gas (other than from my heavy highway foot) from nearly flooring the pedal to avoid the jerking back that the car does. i should probably add that it only does this on the 1st and 2nd gear (i think) the rest shift normally like while driving highway speeds.
i'm not really good with the insides of cars but i think i kinda described whats going on .__. ...
do you guys think this sounds like the transmission needs to be replaced or could it be something else? maybe something cheaper to fix... lol. my list of things to do to the car is adding up a lot... thinking about an 03 g35
that kind of sounds right to me just from reading X] but would that cause the car to jerk like that because its shifting gears at the wrong time?Paul Wall wrote:I think its a TPS* issue, The TPS tells the TCU* how much the throttle is depressed and therefore telling it what gear to shift into.
How does the transmission fluid smell and look on a white paper towel?
TPS=Thottle Postion Sensor
TCU=Transmission Control Unit.
it's a 1994. i believe i'm due up for a timing belt change. on the timing belt box its engraved that it was changed at 104,XXX miles and my odometer reads 156,604 although the gears on it are broken so now i'm not sure how many miles it has... probably should go ahead and change it just to be safeyodawill2000 wrote:yup
What year is your J ??
TPS adjustment affects engine idle speed too. Is your engine idle speed high?unlimited wrote:
Miles and not kilometers?yodawill2000 wrote:They should have used a Kevlar belt that's good for 105K miles
it's 900 rpm in park and 750 in drive with the brakes applied and no a/c or heat nor accessoriesGerryO wrote:
Keep that in mind...unlimited wrote:... lol. my list of things to do to the car is adding up a lot... thinking about an 03 g35
Modified by unlimited at 7:05 PM 2/10/2009
thats what makes me think about getting a car that is in well enough condition that when its in my hands, it will run and last for years to come. i'm really good and into taking care of everything i own and i've always had in mind how i am going to take care of my car as if it was my child but this j30 (although it rides pretty well, just things here and there) doesn't come too perfectly maintained and i figure i'm better off getting something that i can maintain well instead of fix up (although i'm not against fix ups if its routine things.) i do plan on keeping this car until the end of the year but if something extremely costly comes up (something maybe in the thousands :S) i'm going to really consider a G35. my eyes have been fixed on them lately o.o (03-04) or maybe a Lexus RX 300 (RX 330 if i had the money...), i really want an SUV X] lol. there's something about them...J30inthe sun wrote:
List of things replaced/fixed last 6 months: (108,000 - 112,000 miles)
Full timing belt kit w/ all belts & idlersAll coolant hosesFront springsFront struts w/ upper mount & bootsComplete rack & pinion unit w/ mount bushingsFront outer tie rod endsFront stabilizer bar linksFront tension rod bushingsFront lower control armsRight front ABS sensorSpark plugsThrottle position sensorIdle air control valve cleaningTrans filter kit & fluidNew rotors & pads all the way aoundNew tires Rear struts & all rubber pieces & boots (1 1/2 years ago)(3 alignments )
Cost to bring to spec:
I have put more $ in than the current Kelly Blue Book Suggested Retail Value of this car rated in excellent retail condition (1997 J30 112,000 miles). http://www.kbb.com/KBB/UsedCar...Ctrue
The way the car runs & drives down the road now? PRICELESS
That's about all i need to hear to finally give up on my J30. That's a lot of suspension work you did there. I wonder if that's normal. I've already got a laundry list of things to fix on my car, but suspension isn't on the list. My piece of junk '94 Mercury Tracer wagon with 100k miles beats my J30 (70k miles) for reliability hands down.J30inthe sun wrote:
Everything in the front suspension have been replaced except the spindle part or knuckle (I think they call it that) & wheel bearings. It is probably not normal but I have about 20,000 miles on the car at 85-110 mph & from what I understand suspension components degrade exponentially with higher speed. Also the roads in Tampa are not the smoothest. I bought the car with 39K on it & have no idea how the previous owners driving habits were however the Infiniti Stealership service records were excellent. By the way the ride is incredible with everything new, probably nicer than some brand new cars especially with the RWD & independent rear.Puddles wrote: That's a lot of suspension work you did there. I wonder if that's normal.
In my 9 years & 75,000 miles my J30 has never failed to start or strand me except when the battery went dead from old age just like any other car. I have never had any major problems. All the work done has been maintenance items. Eventually any cars suspension will wear out. Out of the 20 or so car I have owned this is by far one of the most reliable the other 2 were a 1991 Toyota Supra Turbo & 1980 Honda Prelude all the other were American & based on my experience I will never buy an American car again.Puddles wrote:...for reliability hands down.
Granted the maintenance on these cars is high because it appears everything on these cars is made especially for these cars only, hence so many stealership only items, but when properly maintained there are not many cars that can compare even new in my opinion.Puddles wrote:
