transmission
allah1
Car: 1993 Q45A
got 1993 Q45a drove it the other day got up to 70-75mph and it would not shift into 4th gear any suggestions?
MattB
Car: 2001 Infiniti I30A
Is the overdrive off button engaged?
louiegz
Car: 2003 BMW 330i, 2007 Audi A3 3.2 Quattro
MattB wrote:Is the overdrive off button engaged?
No overdrive Button in the Q. Might have a problem. The experts will soon chime in.
qship96
Car: 1996 Infiniti Q45
how long have you owned the car?how many miles on transmission?how is fluid level and color?what is maintenance history of transmission?
Romeo5k
Car: 1995 Infiniti Q45~296k miles -- DEAD
2012 Nissan Altima 2.5 == 100,305 miles
allah1 wrote:got 1993 Q45a drove it the other day got up to 70-75mph and it would not shift into 4th gear any suggestions?
With the questions above , answer this for me also. When is the last time u got an tune up period? You could be jumping time. Dont drive it too much and dont force it to go over. Also how is it switching gears when u take off? is it sawitching smooth and on the right spot, or is it switrching rough or taking too long to switch gears. All that matters as well.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
louiegz wrote:No overdrive Button in the Q. Might have a problem. The experts will soon chime in.
Well, there is a OD lockout button on the FY33.
The others are gated.
Rex
Car: None
Failure to shift into 4th at highway speeds (& RPMs) is a tell tale sign of a dying transmission. May try a fluid exchange or (real) flush, with pan drop and filter change, but any benefit would, most likely, be short lived.
transmission replacements are expensive, need to think long and hard about how many more miles you plan on driving this Q, and what else may need to be addressed in the coming year/2 years. Have the timing guides been "done"?
Peterofdevon
Car: 94T 70K, miss mannors, 96 Black on Black 72K, raw sex
Up shift failures may be casued by a stuck spring or clog in the valve body. Ask around your city for the most reputable trans shop and have them give you an estimate.
But first I would get a power flush and see what happens...which will be one of three things;1) no change2) it gets worse (which it would anyway)3) it fixes it.
Peter
redmanfx
Car: 92 Q45a
This is a classic thing that happens right before the torque converter blows as well...... really need to check it out ASAP!!
Que-45
Car: 03' Y34 Black/Black
My transmission would not shift out of 2nd gear. I pretty sure it's shot. So I went and picked one up from a local yard, dropped the pan and it looks brand new in there, fluid was good. New gasket and filter are on the way from joe at everything infiniti. I pulled the old one out of the car tonight and let me tell you guys if you have never done it, you are in for a real treat. I had to use every extension and swivel head socket ever made to reach some of those bolts. I think I'm going to do a write-up.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
3 foot extensions for the top bolts. Many are never reinstalled.
An article would be most welcome, especially if you didn't use a lift (Oh, the agony!)
Modified by maxnix at 11:05 PM 9/11/2006
allah1
Car: 1993 Q45A
had the car 5months it has 121,000 on it
allah1
Car: 1993 Q45A
taking off is smooth and all the way up to 3rd gear it drives good
szh
Car: 2018 Tesla Model 3.
What rpm's are displayed when you are at a constant 70 mph?
Z
allah1
Car: 1993 Q45A
THE RPM IS AT LIKE 4000 WHEN I'M DOING 70 MPH.
Q45tech
3rd gear is 480 rpms per 10 mph............70 would be 3360 rpms2nd gear is 740 rpms per 10 mph........... 70 would be 5180 rpms
4,000 does not compute.
sijoko
Car: Black 1994 Infiniti Q45 Turbo, Pearl White 2014 Maxima Sport
You need to start with the basics.
First, have you checked the fluid level as shown the manual? It has to be done on a level surface with the engine running.
Second, what condition is the fluid in? Have you changed it recently?
allah1
Car: 1993 Q45A
I HAVEN'T CHANGED THE TRANS FLUID SINCE I HAD THE CAR. I CHECKED THE FLUID AND IT LOOKS DARK BROWN AND BURNT. DO YOU THINK I SHOULD GET A COMPLETE transmission FLUSH?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Either that remanufactured transmission.
Please, LOSE THE CAPS KEY! We can read just fine without SHOUTING.
Modified by maxnix at 4:23 PM 9/16/2006
Bayarea Q
my 95Q with 150K miles just started this as well about a month ago.
Every once in a while it will shift into dirve, but than immediately downshifts into 3rd. However I had 5 people in my car on the freeway the other day, and I manually put the car in second and stomped on it....anyway, now it shifs into drive and stays. Weird....perhaps the transmission just needs a tune up. Or something was stuck, and my hard shift cleared it out. BTW, Mobil 1 flush with pan drop / filter change every 30K. Funny I have exactly 30K on the current fluid...maybe I just need a flush.
Q45tech
How does it look, smell, and taste [ugh or ummy] [kidding]............the drop from the dip stick vs the drop of brand new [side by side] is usually all it takes to see the reduced saturation of the dye color from heat breakdown.
As we all know synthetic ATF just prolongs the inevitable failure by some amount of time.............always put that $300-$400 per year away for transmission replacement.
