slydin'240 »
https://forums.nicoclub.com/slydin-240-u14906.html
Sat Jun 17, 2006 1:58 pm
It's really not that hard to do at all. Remove shifter, dissconnect all wiring harnesses, remove bolts from driveshaft at the rear end, remove ALL bell housing bolts (tricky one dead center of bellhousing, remove 4 bolts from torque converter and flywheel, remove trans crossmember (make sure to have jack under trans,) and remove the starter. It alittle out of order but I think that is it.Oh yea don't forget to remove the trans lines going into the radiator.
