Transmission????
Saltman
Car: 1990 240sx fastback
At first I thought it might be the clutch because it started to grind when pushed into gear. But I've only had the clutch (Exedy stage 2) for a year now. So now, I think it may be the transmission. It makes a funny noise when the clutch is pressed all the way in sometimes that sounds like a whirring/whining. Anyone else had this problem??
EludeR
Saltman wrote:At first I thought it might be the clutch because it started to grind when pushed into gear. But I've only had the clutch (Exedy stage 2) for a year now. So now, I think it may be the transmission. It makes a funny noise when the clutch is pressed all the way in sometimes that sounds like a whirring/whining. Anyone else had this problem??
Sound's like your pilot bushing needs to be replaced your thorowout bearing maybe giving you problems as well.
Saltman
Thanks. Has anyone ever replaced these? Is it simple to do or should I take it to a shop?
S13240
If you've done a clutch job, you can do this.
