Transmission swap
Low N Pro
Car: 98 Mustang 3.8L
06 G35 Coupe Bone Stock for now
I would like some experienced advice on this idea. I have an 06 AT g35 coupe, a friend of mine will sell me his 6 speed transmission for 300 bucks. He swapped an LS3 into his 04 g35 coupe and has no need for the transmission. I'm wanting to convert mine to a 6 speed. I'm curious as to find out if I do this swap will I have a constant CEL or is there a way to set it up so I won't have that and my gear indicator still works on the gauge cluster.
Yosip1115
Car: 2005 G35x- Brilliant Silver
OEM rims- XXR 522's soon.
CAI
Osiris uprev
electric exhaust cutout (sleeper)
RWD switch
Chrome/mesh grilles
coupe sport tuned springs
grounding kit
headlight LED strips
Same question here except mine's an 05 g35x
biggie
Both are probably possible, except the G35X would have to be converted to RWD probably.
Both are probably going to be expensive and long projects.
I'm not sure on what all the computers control with the AT, so may have to buy all 6MT computers and swap them out.
Along with:
2 pedals, drilling firewall
clutch master/slave/line
Not sure on difference in AT/6MT flywheel/crank mounting
Center console change out with 6MT setup
Someone has probably done the 5AT to 6MT on a non-AWD Sedan or Coupe, should be able to search the internetz.
Low N Pro
Yeah A friend of mine is getting me everything for about 700 bucks and ill have a 6 speed. I just dont want a CEL on at all times and a useless shift monitor in my gauge cluster >.< I'm new to infiniti s but ive been working at a toyota dealership so just looking for insight.
Thanks
joe603
Car: 2014 Durango R/T
I've heard of people doing this for around 10k. There is a lot of fab work needed to get the transmission to fit. You will also need a new wiring harness and ECU (or aftermarket). Unless you have a show car, it's really not recommended...just get a 6 speed.
Low N Pro
10k? Seems a bit out there for just a transmission swap. I know the firewall will need to be drilled but the undercarriage needs fabricating? Luckily this buddy of mine has all I need to get rolling hes also including a bunch of other goodies just for the simple fact to clear space. I hope it doesnt come out to be that pricey
audtatious
Parts list: 6MT Transmission, Clutch, Flywheel, Clutch line, OEM clutch hardline, OEM clutch fluid reservoir, 6MT driveshaft from a G35, 6MT shifter, Throwout bearing, 6MT wiring harness or modify the auto harness if you know what you are doing, Clutch pedal assembly, Brake pedal assembly, Center console, Shifter trim, Center console sides (the sides of the radio), shift knob, shift boot. Probably other miscellaneous things as well. You do need to cut a hole in the floor for the shifter since the automatic is a drive-by-wire design. You can use the OEM ECU but you will have a code which you can probably get rid of via a Uprev...else source a 6mt ECU (if they use the same cabling....you will need to check).
Here is another thread with additional information concerning the GTM kit/whatever...: info-needed-g35-5at-to-6mt-transmission ... 57272.html
joe603
thanks Matt, forgot about that post!
audtatious
Google search led me right to it ;)
Low N Pro
I'm going to be doing it myself I have never taken a vehicle I have owned to a shop unless for paint or tuning. Looks like this job will be quite fun IMO. Ill be sure to let you guys know how much I had to come up with to swap it so others will know thanks guys
audtatious
Take pictures and document the process here. It's something I'd sure watch :)
Low N Pro
I sure will I'm always willing to post out info to help people find an easier way to save a little cash when it comes to their cars. This forum has always been a help for me, i joined when I was 15 and got my first 240sx just lost account info to my last account : (. It's good to know there's people with the same passion for cars as I have.
audtatious
Do you know your last account name?
Low N Pro
No sadly not :/ all i know was I had a 90 240sx hatch and I posted pics of it back in 08-09 under the 240 forum
audtatious
Yeah, not much to go on :)
Low N Pro
Yeah if i come up with it ill find it, my 240 was fun for a first car but i have to say i like my G quite a bit : )
Low N Pro
Ok so i purchased the 6mt transmission got it and the driveshaft for 250 bucks. Here soon ill be putting it in if anybody is interested ill post pics of the swap. all in all its going to cost me around 700 bucks all together
Youngc845
Car: 03 G35 Coupe 5AT
how did the swap come out?
telcoman
Youngc845 wrote:how did the swap come out?
Probably still trying to get it to work
Telcoman
joe603
This is not an easy swap...custom fab shops have done it and made it look OEM...but it's pricy.
