evildky »
https://forums.nicoclub.com/evildky-u13100.html
Tue Jan 12, 2010 9:14 am
I did the SX swap and alter swaped it out in favor of the stronger T5, to do the sx swap you need a front case form a 4 speed and the rest form the sx, you then enlarge one countershaft hole, clearance the inside of the front case and swap pver the countershaft bearing, then you need a custome drive shaft
the easiest swap is a 79-83 280zx n/a 5 speed, it's pretty much plug and play, the T5 is harderto come by but it a lto stronger if you itend to make a lot of power, but unless you add forced induction the n/a 5 speed should be fine
