transmission swap
ILUVJDM
Car: s14 240sx
soo my trans had went on me so i jacked the car on 4 jack stands and took the trans out now im trying to put the new one in but seems impossible to get in do u have any tips or tricks that might work for me???its been sitting in my garadge now for a couple months and im dying to get it on the road.
CSUPUEBLOTIM
Car: 1992 240sx Sr20det Coupe Silvia Front
What exactly is holding it up from going in? Maybe make a make shift transmission jack with a floor jack. Use the jack and maybe a piece of wood and get the transmission on it so that its pretty much at its center of gravity and use a strap or something to secure it from falling off. Then, roll it under and raise it up and work it into place. You can try putting a shot of WD-40 on the dowel pins if they need it. I am so glad I have a lift for stuff like this. Jack stands FTL.
snake240
Car: 92 hatch SR20DET
if they are identical it should go back in. did you change clutch or anything. if so maybe thats not aligned right. worse case get a micrometer and compare input shafts. other than that should go in.
Hijacker
Car: '92 240sx Convertible
'94 F-150
CSUPUEBLOTIM wrote:I am so glad I have a lift for stuff like this. Jack stands FTL.
Pshaw. I can swap out a trans faster on stands than I can on a lift.
OP, make sure that you have the trans level with the motor when you're putting it in. Also, be sure to roll it a few degrees left and right. You may be getting hung up on the splines.
boro drift
Car: '87 Supra, '92 240 with SR20 and '98 12 valve Cummins
Scream obscenities while trying to install the trans. That works for me.
