NolimitZ32 wrote: ↑Tue Oct 31, 2017 10:24 am
From experience I would say you are better off pulling the trans first out the bottom and then pulling the engine out the top. Screwing with a leveler is a huge PITA and in my multiple pulls (I've honestly lost count) I have found it MUUUUUCH easier to swing the engine without the trans in and out of the car. Just make sure that your jack stands are tall enough before you start, It sucks getting the trans out and laying on a jack, yes you will need a floor jack to lower the trans unless you yourself are jacked (pun intended) only to find out that the car is too low and you can get the trans out from under the car.
Great stuff NoLimit...PO, this is what I meant about precious space and knowledge of having worked deeply on Z32's before. As you noticed and mentioned, working under the hood in a Z32 is a really, REALLY frustrating and complicated, body-ache-inducing job that benefits from ANYTHING that clears up the mess and/or makes room to work and see what you are doing much less do it, and finding out too late that you have a major issue can be a real crusher.
Another thought is to be SURE you have everything you need for the job, and as you mentioned DO consider any other maintenance that can be done while you are there since obviously a repeat visit won't be fun.
Good Luck!
