Fibre guy »
https://forums.nicoclub.com/fibre-guy-u128603.html
Fri Aug 14, 2009 8:30 pm
You can get a KA manual transmission for anywhere between $50 and $400. For rebuilt I don't know.The clutch assembly is normally easy to find in a U-pull-it, hopefully you can find the line from the clutch master to clutch slave cylinder.I would recommend a new clutch master and slave.The last parts you would need are the clutch and flywheel. your choice of stock or performance.People have done the swap for pennies on the dollar in 1 night. Others spend a small fortune on having a shop do it. Just search around here on NICO for a write-up on it, there's lots of them.Manual is worth every penny in a 240 IMO.
A normal mechanic will probably charge you out the A$$ for labor. (500-1000)
