greencar wrote:Check and see if the u-joints are phased together.
-Dan
Um...what??
I'm gonna say something you may not like here (= you may need to learn how to drive a stickshift. Sounds like you're not using the clutch properly, since the problem is centered around the low rev range. As for still feeling the stutter at higher RPMs, you may want to put it on a chassis dyno (not a power testing dyno, mind you, this version is for driveability issues) and while it's rolling, check your driveshaft and center support for any play, it may be out of balance, or the support may be worn out. The mounts mentioned earlier can cause a bit of a stutter, since the engine is hopping around in the bay instead of delivering power.
Or the engine could be worn out. I had an old beater Tracer some years back that did that same thing. I had to re-learn how to drive the thing because the motor didn't have enough power to push the car around properly, so it'd keep winding up the clutch and running out of push, causing the jerking sensation.
