Eddiemac »
https://forums.nicoclub.com/eddiemac-u107270.html
Fri Apr 15, 2011 11:28 am
My vert does this too. Im pretty sure its the TCU that needs replaced. The easy way to deal with it is to put the car in neutral while rolling, turn off and restart it. Mine only does it once every couple months. If you have a good unit you could swap out that would be the way to go. I believe its under the dash, above the ECU.
