transmission smokes
bigred240sx
Car: 91 240sx fb w/ super hicas(wrecked)
1976 280z
2009 frontier
Ok the title says it allrecently my second gear started to go out (i guess) i couldnt down shift into it so i replaced transmission fluid to proper levelsi did notice the lower shift boot or whatever it is called was torn and the new one will go one tomorrow evenin after school and workbut right now when i high rpm my car it smells bad, smoke come out from my transmission and shifter area, and my gears try to lock upanyone have an idea i searched the forums and found nothin as well
White Comet
Car: fc, s13 and mazda6, Sierra
is it making any grinding or just smoke?
s13fOr_me
Car: 240sx
maybe spilled transmission fluid?
bigred240sx
1976 280z
2009 frontier
grinding on upshift and downshift to second but right now i baby it and skip second completly and havent hit high rpm in a week i guess
574-240sx
Car: Nissans, Toyotas, Subaru
How low was the trans on fluid, you may have done some pretty bad damage to it.
bigred240sx
1976 280z
2009 frontier
thats the thing it was really that low but what came out was ****ty and just gunky my car was flooded 2 years ago but everything was rebuilt and when i bought it i was told all the fluids in it were fresh
White Comet
it sounds like ur fluid was long overdue and probably killed it. might be bad gears
bigred240sx
1976 280z
2009 frontier
well damn i didnt wanna here that maybe someone will hit me tomorrow and let me get a new one(240)
574-240sx
Transmissions are cheap, I don't think I have ever spend more then $150 on a used trans. You might have had a rear main seal leak and not even known it. Usually a manual transmission starts to make humming sound when its low.
bigred240sx
1976 280z
2009 frontier
it does that only in 5 at low rpm like 2100 to 2700
White Comet
i agree, trannies are cheap, swap it out and while ur in there save urself some trouble and do teh rear main seal, clutch unless its newish and other things like that
bigred240sx
1976 280z
2009 frontier
ok thanks guys i was just wondering why it did this
White Comet
good luck w/ it. if u dont have proper tools and garage this might be a pain
bigred240sx
1976 280z
2009 frontier
yea i got a lot of tools for this but my garage is a little unworthy with 1 jack and 1 jackstand
White Comet
get a friend it it shoudl be doable, i helped swap a rear dif and we dropped it on my friends chest
