ATF = ATF, so not really an option.KA24JEF wrote:well you culd be low on fluid or just need to to be changed to something thicker
There are no weights, like motor or gear oils. There's Dextron IV etc etc, but if his transmission is slipping, it's not the type of fluid. It's the age or amount of it.KA24JEF wrote:your righ atf is atf if its an auto, but if not thir are allkinds if transmission oil
I didn't think I had to say that, but yes, lol.es.biggs wrote:After trying to figure out the logic in some of the responses in this thread, I figured it'd be a good idea to throw this out there:
Manual transmissions don't slip lol.
robomatic12 wrote:LOL briggs. I'm assuming because the OP said possibly the clutch plate he has a manual transmission. It is possible with a misadjusted clutch pedal for it to start slipping once the fluid warms up. It is also possible the clutch disc is toast or the pressure plate has given up. OP try adjusting the clutch pedal free play and see if that helps.
