Clyons0203 »
https://forums.nicoclub.com/clyons0203-u34374.html
Tue Feb 03, 2009 7:09 am
Ive been working on the car a little bit. NO ECU codes. No transmission codes.According to previous owner, the car has been dealer maintained since he bought it back in 1993. Every service item has been done. The car is very very very clean for a 93 with 193k miles. He said the transmission started to slip so he drove it on home and let it sit.
Car will not shift because it cant build up enough speed to shift out of 1rst gear.
Start car up, move shifter to drive (rpms rev for like 2 seconds around 1500rpm then drop down to idle (car is now in gear), press on gas car barely moves and revs up.
Either the first gear clutch is completely shot, or the torque converter is shot, or its not building up enough pressure.
My money is on the torque converter. No codes, clean transmission fluid, dealer maintained, I think the torque converter just wore out.
What you guys think. I used the pedal and shifter sequence to make it spit out the codes. And used a nissandata cable to check the ecu for codes.
I wish i bought conzult instead so I could make the transmission do a self test.
I also did a torque break test. Put car in drive, foot on break, give car gas.......rpms just climb and climb
