Shoot me an e-mail I have a transmission if you need it.jarred15801 wrote:Sometimes when i startout from a stop and just giving it a lil bit of gas, for example going through a parking lot or congested stop lights. my car seems to go fine through 1st gear and then when it gets to about 2000 rpm's it tries to shift into 2nd i believe and it's like it doesnt grab because it just revs to 3000 rpm's and then catches and shifts and the rpm's drop back down. then the rest of the gears are fine. it doesn't do it all the time either. anyone ever have this problem? or any idea what it is?
i just bought the car with 99k miles on it and ive put on a thousand. i don't know the last time the transmission was flushed so im getting it done next week hoping that will fix it.
I hope it isnt an original transmission to one of the 3 super high mileage Q listed in your signature....nothing like replacing a old worn part with another old worn part!!!bullittandy wrote:
This post is kind of rude-especially since you have little info about my parts. However, if you'd left the off then it could have been tolerable and maybe even funny.qship96 wrote:
You don't sound very sorry.qship96 wrote:I'm sorry, please forgive me.
Well, you could try waiting for the car to reach operating temperature before......well.....operating it.kraftdp wrote:I have almost the same problem, but mine only happens when transmission is cool (usually just the first shift), and only at higher torques. I've had this problem for 2 1/2 years now
So long as I remember to baby that first shift in the morning, she shifts smooth and solid. No other shifting problems...
Where do i find these resistors? and how do i find the "dropping" one?carmo wrote:Under heavy accel it doesn't slip? sounds like a low line pressure issue at low throttle position. Find the dropping resistor and unplug it, if the car has one. Nissan autos do. when you unplug the dropping resistor the TCM goes into fail safe and maxes out line pressure. It's gonna shift hard as crap but if it holds under light accel then youve pinpointed the prob. Your still gonna need to rebuild. This may keep you on the road a little longer however...goodluck
The dominant concept here is "operating temperature."msogun wrote:Mine is like that. In the morning it woun't go into drive "D" until it warm up. After 2 minutes, everything is perfect. Sometime I move if to 3 and when it warm, shift back to drive. I have been doing that for about 3 1/2 years with no problem.
Is the low line pressure issue a fixable one? I think that could be the culprit to my AT's shenanigans. Light acceleration is cool, as well as load. But medium "daily driver" acceleration and my 1-2 shift is a neck snapper/drink spiller/big PIMA.carmo wrote:Under heavy accel it doesn't slip? sounds like a low line pressure issue at low throttle position. Find the dropping resistor and unplug it, if the car has one. Nissan autos do. when you unplug the dropping resistor the TCM goes into fail safe and maxes out line pressure. It's gonna shift hard as crap but if it holds under light accel then youve pinpointed the prob. Your still gonna need to rebuild. This may keep you on the road a little longer however...goodluck
