airmarbury »
https://forums.nicoclub.com/airmarbury-u248869.html
Thu Jul 09, 2015 7:13 pm
When downshifting, I let computer to control my transmission and no matter what mode you use ( D, DS, Manual or Snow), you always feel the shutter when it comes to stop.
OK, here is the whole story, I got car from infiniti dealer (they recommended a new TCM because I have warranty and I said YES )
FOR THE FIRST WEEK
Engine RPM is stuck at 1000 when idling (the normal is around 600 or 700) and It was very hard for me to stop my car at low speed ( between 0 – 30km/hour). For Example: when traffic lights turn to green, we normally release brake and give a little gas so it moves. But my car is different, you release brake and then it accelerates by itself and you have to hit brake to slow it down. In other words, you don't need to give gas between 0 – 30km/hour and if you don't want to hit the car in front of you, you have to hit brake to slow down because it accelerates too fast.
However, if your speed is over 30km/hour, everything becomes normal.
AFTER ONE WEEK
All problems happened during first week are gone but there are three new problems
1. You feel shutter/hard shifting every time when it comes to a stop.
2. You feel a hard shifting (more like ..jerk forward) sometimes when downshifting from 5-4 or 4-3
3. I also noticed that my brake becomes so spongy but after few minutes, it becomes normal!!
A lot of people from Nico Club told me it is caused by the transmission fluid so I brought my car to a Nissan Dealer, They told me Infiniti Dealer doubled the recommended amount of my transmission fluid. It makes sense to me and also explains my problems during the first week. Due to the high pressure in transmission, transmission can not downshift to lower gears and that is why this car accelerates by itself from 0-30km/hour and engine RPM is 1000 ( Vehicle speed sensor tells TCM, Transmission Control Module that engine speed must match up with transmission gear)
After Nissan corrected my fluid level. Brake problem is completely gone and Shutter is getting better (You still feel it but just not as strong as before)
I already got 2 guys to check my transmission fluid so I am pretty sure it is no longer caused by transmission fluid. The reason I asked if it is normal for transmission downshifts from 3- 1 is because I suspect there may be internal or physical damage in my transmission.
I traded my 2006 BMW for this car and only enjoyed the “smooth transmission” for 3 weeks . It is really not funny because I still own $20,000 for my car loan. Infiniti Canada hopes me and the dealer can reach a common ground. Nissan told me they can do easy work but I have to go to Infiniti dealer for transmission problems. I spoke to some licensed technicians and nobody is willing to testify with me in the court. I spoke to Government and they refer me to BBB. I called a lawyer and he told his friend has similar problem but there is nothing he can do. The lawyer asked me to sell my car to someone but I feel really bad (what is the difference between me and car dealers !!!! ) There is a nice transmission guy told me they can provide a legal assessment for me but I have to drive it a lot ( especially in downtown with frequent stops because I need to make my transmission worse so that dealer has to fix it under warranty) Currently, I just want to know what causes this problem ( or what parts need to be replaced) so that I can prove myself in the court….Sorry about my complaints in here but it really sucks !
Anyway, guys, thank you so much for your help… Hopefully I can find an honest technician or nice lawyer …..
