Transmission shifts hard...
9ball
Car: gamb|ing at pool
Hello, I'm in Japan and have a 90 Q's Silvia with a CA18DE. The shift from 1st to 2nd is a little jerky and I wondered what to do to fix it. I've used the machine where you pump fresh transmission fluid in, start the car and put it in each gear for 5 seconds, then pump that fluid out and new back in. It shifted better for a day or so then back to the way it was. It shifts perfect after I get up to highway speed, or after I run the engine up to about 6 grand but when it's cold it shifts a little late and not smooth at all. Does anyone know what else to do or is this typical among Nissan automatics?
:help
APEXi240
Car: 08 Nissan Versa S hatch
How many miles are on the transmission? It might just be f**ked. My Sentra was doing this, and it was simply due to transmission wear, wouldn't have been fixed unless I got a rebuild.
9ball
It's sort of tough to go by mileage in Japan. It's got about 60,000km on it (about 36,000 miles) but that's fairly normal for a 10-15 year old car in Japan. Things are much closer together here.
Two-Forty
I heard in japan any car over 35k gets their engine replaced, it's cheaper than maintaining it due to emission laws, but I heard I do not know..
240canuck
my transmission shifts pretty harsh from 1st to 2nd due to a bad shift selenoid get a transmission shop to check it out for you they can hook up the diagnostic tool to it and get some codes and see whats wrong.
Nismo_Freak
Car: 89 Nissan 240SX
Your synchro also may be damaged. Make sure you are also using the correct weight in transmission fluid.
cnichols
Car: 96 Nissan 240SX
99 Infiniti Q45
93 Ford Fastiva
240canuck wrote:my transmission shifts pretty harsh from 1st to 2nd due to a bad shift selenoid get a transmission shop to check it out for you they can hook up the diagnostic tool to it and get some codes and see whats wrong.
Same here. That was 4,000 miles ago and only does it every once in awhile. Dealership quoted me $600...yeah right.
