It will rev really high (3-4000 rpms or more) before shifting - usually I have to let off the gas to allow it to shift. This was doing the trick at first, but now sometimes even when I let off the gas it doesn't want to shift. The problem usually only occurs when I first start driving the car. After I've been driving for a while it seems to go away. The transmission doesn't seem like its slipping, and when I'm on the freeway it drives fine.
Also, when I started it in my driveway a few days ago, I shifted it into Reverse and heard it make some type of a whining noise (lasted about 1 and half seconds) after I shifted. I shifted back to park, it made the same noise. Back to reverse, then drive, and it made the noise each time. I gave it plenty of time to shift before I gave it any gas and started driving. It only made this sound in my driveway that one time, and hasn't done so since.
Does anybody have an idea on how to fix this? I've heard that adding a Lucas product may cure the problem, is there truth behind this? Is there a part inside the transmission that needs to be replaced? Or does this transmission need a complete rebuild/replacement??
I did check the transmission fluid when I bought the QX4 and it looks good, red/pink in color. Please help!
