I've been reading the posts on here for a couple of days now and saw a similar problem that was solved with a loose wire. Is this my problem and if not, what is this wire and where does it go? It appears to have pulled out of a connector or a sensor, but I cannot see or feel any plug or broken wire that it goes to. My transmission shifts in and out of overdrive and I don't want to drive it this way for fear of damage. I cant get a picture to load so the description is as follows, a white wire in a black sheath on the back of the engine at the top and about 14" long from where it comes out of the connector at the harness. Any help is appreciated, thanks ,Jeff.
EDIT: pics
http://s244.photobucket.com/al...0/j30/
Modified by tsmg1 at 5:26 PM 3/21/2009
