Transmission service
Discussion of Infiniti's amazing (and underrated) sport-luxury crossovers, the EX35 and EX37. For 2014, the EX series will be renamed QX50, in line with Ininfiit's new naming conventions.
artsch
Car: I have a 2008 Infiniti EX35 Journey
Hi all, well the maintenance manual does not say I should change or flush the trans fluid in my 2008 EX35 2WD Journey. In places it does say to change the fluid there is a notation not to change the trans fluid in the EX35. Can someone tell me why we do not need to do this but my dealer says I should get a transflush at every 30K? This is from the manual:
Transmission Fluid – Automatic or
Manual, Differential Oil, Transfer Case Oil
Visually inspect for signs of leakage at
specified intervals. If towing a trailer, using
a camper or car–top carrier, or driving on
rough or muddy roads, replace the transmission
fluid/oil at every 30,000 miles or
24 months (except models with 7-speed
automatic transmission and the M35/EX35
with 5-speed automatic transmission).
jmess
Nissan is a big thumbs down on the flushing sales pitch. If you are going to keep your car for 100K+ then a drain and fill might be worth it. I will wait until 60K before I do mine.
post5647094.html?hilit=flush#p5647094
Return to “Infiniti EX35 / EX37 and QX50 / QX55 Forum”
