Transmission sensors leaking....best fix???
amolao
Car: 1989 Hatchback (the first one...) w/ Autech sr20de S15
All 3 sensors in my trannie are leaking....What should I do in order to stop the leaks???
(Manual tranmission, S13, 1989)
Maybe some teflon tape around threads??? The sensors seem to be working fine is just a small leak that gets all over the transmissiion and makes a mess down there...
thanks
s13sr20chris
teflon tape or rtv would work. or just a simple blind eye
amolao
Try explaining that to my wife she is tire of the little puddles of oil on the driveway..... Ohh..I love my baby (taking about my car...)
navysnail
teflon tape will do the trick, in the FSM it says to use thread sealant
s13sr20chris
puddles? oh, better fix that then. the puddles are clean gear oil right and not black/brown motor oil?
amolao
Yes it is gear oil, I check underneath and clearly see where the sensors area is moist and wet, I took them off and reseal with teflon paste, Im trying to take care of all deficiencies (Im very picky...) before my car goes to the paint shop this week.....I also got a new wing for it, I will post pics later after paint job.....
thanks for the help guys!!!
amolao
I have a small oil engine leak (after chain replacement) but that one is going to stay.....is the infamous "oil pan leaking somewhere" leak, HEHEHEHE!!!!
