onecrazyfoo4u »
https://forums.nicoclub.com/onecrazyfoo4u-u42462.html
Thu Jul 12, 2007 8:00 am
I'm just trying to figure out how to get my reverse lights to work and what these other sensors are. There's no loose connections that will hookup with my 2 unhooked sensors, so I'm guessing you have to solder them in? Up by the front passenger side tire and tie rod, there are 4 cut wires dangling, and one 7-wire connector. Anybody know what those go to? How do I find out which wires to hook up to my reverse sensor?
My speedometer works just fine, just curious if this is the speed sensor, the big 2-wire hookup on the bottom of the transmission?
And secondly, is this the reverse light sensor? It's on the passenger side of the transmission, furthest one up by the engine, but behind the clutch slave cylinder. Has a two wire hookup and seems to be leaking alot of transmission fluid:
And lastly, what is this sensor for? It's also on the passenger side, but right above the speed sensor, further back on the transmission. It's a 2 wire hookup also:
And for all of these sensors, they seem to be leaking alot, is that normal? Can I just tighten them with a wrench, or is there a special of putting them in and taking them out? Sorry for all the questions, just trying to figure stuff out!
