sandersb »
https://forums.nicoclub.com/sandersb-u78770.html
Tue Jan 20, 2009 5:59 am
If you're just pulling the transmission to replace the clutch, you do not have to drain the fluid. Just unbolt the slip yoke section of the driveshaft which goes into the gear housing and leave it in the transmission, should be three bolts, and that way the fluid won't come pouring out.
The top bellhousing bolts can be reached using extensions, universals will make it easier.Other than that, you should be good
