TachyonS14 »
https://forums.nicoclub.com/tachyons14-u10260.html
Sat Jan 31, 2004 8:56 am
I found the transmission VERY easy to get out if you jack the car up, and put a floor jack under the oil pan with a block of wood in between so you don't dent the pan. Then, take out the motor mounts and let the jack down a little. This way the engine and transmission will be lower. Now, those top pesky bolts on the bell housing are SO easy to get to now. If you are not good with cars, I don't recommend this because you have to check all your lines up top so when you lower the engine, you don't stretch or rip anything. So, If you do it my way be VERY careful. When you lower the engine a few inches the only thing I can remember that will get caught Is the radiator fan. Make sure you pop It out of the shroud.
