My transmission is good, I just need the bellhousing for my manual project.AZhitman wrote:Hmmm. Hope you don't need the actual trans, as it may have suffered some heat-related damage while the engine was melting down.
I've never pulled an automatic transmission without unbolting the torque converter from the flexplate first.AZhitman wrote:I don't see why you couldn't just unbolt the trans and pull it - Why would you need the motor to turn?
I've never had a Q45 trans. off but...anlasak wrote:So does that mean I can just pull the transmission without unbolting the converter?
Transmission has been drained and the convcerter shouldn't dump too much ATF. (Tomorrows gonna be a messy day)AZhitman wrote:Exactly what I'm thinking - it's gonna be messy but it should come right off.
Which plate are you talking about?3rd Q wrote:Anlasak, There is a thin plate (flexplate?)that has to be unbolted as you pull it out from the engine, but it's no problem. Paul
3rd Q wrote: There is a thin plate (flexplate?)that has to be unbolted as you pull it out from the engine, but it's no problem.
NICO Night Crew3rd Q wrote:Anlasak,
PS- I'm always amazed that I'm not the only crazy Q guy on NICO in the middle of the night .
Modified by 3rd Q at 2:21 AM 1/5/2006
You got it! Paulanlasak wrote:
NICO Night Crew
Does the plate look like the one in the photo?
3rd Q wrote: but I'm going to sleep .I'll leave the Infiniti problem solving to you and Gary Coleman ( I mean Sqeefoo ).
