Ryan Heo »
https://forums.nicoclub.com/ryan-heo-u67107.html
Fri Jul 06, 2007 7:55 pm
HiNow, I tell you what was going on yesterday.I went the shop where I replaced the front passenger side axle to tell them I replaced the seal two times, but it is still leaking.I guess the axle is very very slightly vent, so I want to change another axle. They accepted my opinion but there was anther promble which is the bracket supporting the axle was broken. They told me unless you replace the bracket first, they cann't work because of warranty. Besides they show me it cost $300. I think it is not my fault because when the seal was replaced, the nut was overtighten so it is broken( I guess). I went to anther shop where the seal was replaced. I said about the bracket with the machenic who replaced the seal. He denied his fault, but he do new bracket for me without any cost.
After that happen I called the first shop "I will replace the bracket by myself, so you guys just change the new axle with free. And I will give you new seal which is a genuin nissan part. Would you chagne the seal when the axle is change?" But they said NO "we will replace only the new axle."
I know the second shop has to have some loss, but I think they should replace the seal because they make the leak first time. So I think they should make to stop the leak. Don't think so?
Thanks.
