transmission rear seal
240banzai
Car: 1990 240sx coupe
i'm in the process of doing an sr swap and found that when i jack up the front of the car the transmission leaks out the back with the driveshaft in it. so i was told by by some guys i trust to replace it. the new seal fits snug on the driveshaft like it should im guessing so oil doesn't leak out. when the driveshaft was in it looked like the seal, old one, was to big for the driveshaft. anyway, i go to pull out the old seal and it wont come out. i finally got the insideof it out but teh outter part of the seal is hard as rock and it wont come out. what can i do to get it out? heres a pic if it helps
Modified by 240banzai at 7:21 PM 4/12/2008
Modified by 240banzai at 9:12 PM 4/12/2008
mister2nr
what I normally do is take a prybar and pop them off with a little force.
240banzai
yeah, but its stuck on there hardcore. you can see scracthes on teh transmission from me trying that already. i'm asking if there is a way to help it come out. like would heating with a heat gun do anything for example, or do i just have to keep picking at it and hope for the best.
h.240
Car: 1991 240sx hatchback
See if you can get your hands on either of these at an autoparts store, or a tool rental store.http://www.bigscaryjeep.com/Bi...2.jpg http://www.v6z24.com/mods/howto/images/ ... 4.jpgThose should do the job.
240banzai
thanks, i'll see if i can tomarrow. that looks like it should do the job.
