amiry36 »
https://forums.nicoclub.com/amiry36-u205953.html
Tue Sep 16, 2014 8:19 pm
The reason my transmission grinds a little when shifting from 1 to 2 and 2 to 3 is because the previous owner has somehow managed to f*** up the already durable differential. He has done some thing that allows the ring gear to move in and out causing the differential to act like it had excessive backlash. When i want to shift from 1 to 2, the differential ring gear moves by allot, causing the transmission to move the gears while synchros are trying to adjust themselves with the matching speed. Hence, causing that small gear grind.
Now if you were to wait a little longer, then slowly shift to 2, you shouldn't hear the grind.
In my case, i just need a new differential. The symptoms i am experiencing seems to be the same as yours.
The rattle sound i get is from the throw out bearing actually rattling when the clutch is not pressed. Not to mention i have solid trans mounts so i get to hear everything. However, since the bearing does not make a sound when is under pressure, there should be no major thing to worry about.
