AnonymousCoward »
https://forums.nicoclub.com/anonymouscoward-u186330.html
Tue Jun 21, 2011 4:52 pm
I just bought a used 240sx, 1996, manual w/ 200k miles.
At high rpms, mostly in 3rd & 4th gears, the gearbox area will rattle a lot. If I put my hand on the shifter it'll quiet down, and if I pull the shifter back by about half an inch and hold it then it pretty much stops altogether.
I've read that this could be caused by the rear u-joint. If so, would replacing it be that expensive?
In the near future I plan on upgrading the brakes & suspension and replacing bushings and possibly the steering rack, so I'd appreciate it if anyone could tell me if I should do any of these at the same time as the u-joint replacement.
Other minor issues: loose trunk/hood, trunk/gas button on driver's side doesn't work, window motor is dead. I assume getting these issues fixed at a dealership would be best, but if anyone has a better suggestion that'd be appreciated as well.
