1. It has recently started on going into 4th (OD) when it's cold and doing a weird thing after letting off the gas and re-applying the gas. It will cruise for a few seconds and then the rpms will go up slightly then back down- but not shifting...?
2. How can I tell if the trans torque converter is locking up? I've been searching on google with no luck.
3. I get a revolution trans error code. where is the rev sensor located? Do I have to drop the transmission
4. Would advance auto would be ok to get the revolution sensor from? (I know your answer
Thanks for the help!
Brian
