IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Mon Jul 05, 2004 11:56 am
if your gonna go manual, your gonna need this-[tt and na use identical manual trans. with the exception of the starter mount location. the tt uses a larger flywheel, and so the starter is placed farther away from the center]
parts-z32 na trans, flywheel, clutch, pilot bushing, slave cylinder, starter.
driveshaft will most likely need to be lengthened. you may need to extend the shifter, linkage to line up with the custom hole you have to cut in the transmission tunnel for the shifter. you gonna have to make a shifter boot also.
