bmconway76110 »
https://forums.nicoclub.com/bmconway76110-u268037.html
Sun Sep 18, 2016 12:54 pm
Hi All
Got a question for about my QX4.
Background: This is my winter beater. I live in Reno and I needed a dog hauler with 4WD to get me up the mountains, maybe do some off roading in summer. I have an Acura that is my "keep it showroom new" work and back car. I paid 2800 for the QX, 132K of it. Guessing based on the filth the last owner didn't care about the thing.
Everything is running fine except for this. If you have driven it for a while, the shifts from 1st to 2nd get wonky. Under light throttle, it will act like it is not sure if it should shift, under moderate to heavy, the shift is a bit harsh. The 2nd to 3rd and 3rd to OD are silky smooth, and the convert locks up fine. When it is cold, everything works as expected.
i pulled the dip stick and the trans fluid is brown, not pinkish brown, brown.
I really have no desire to dump any money into this. It may get 3000K on it a year, and if it last two years, I am happy.
I was thinking as first try to correct this issue, I would just drain the trans fluid and replace what is in the pan with new. My thought is even though a lot will be left in the convertor, cleaner has to be better. If the problem improves, I will do it again, if not, I will just live with the issue.
Thoughts? Comments?
Thanks in advance.
