fastpathy35 »
https://forums.nicoclub.com/fastpathy35-u144977.html
Fri Nov 16, 2012 12:45 pm
Sloppy shifts, 4th gear doesn't grab hardly at all. Took it to a transmission shop they said it was bad. I don't know, the overdrive light isn't on, they ran diagnostics and drove it a little bit. I noticed it started with getting on the freeway, downshifting to 2nd to accelerate, it slipped for almost a full second while it slowly engaged. I changed fluid and filter old fluid was...well, used ,but not burned, and there wasn't debris or flakes in it. Aside from the long, sloppy shifts, 1st 2nd and 3rd will hold under WOT.
I've driven my pathfinder hard. It's not been babied, so I expect stuff to tear up. The only thing that throws me off is everything happened within two weeks, the 4th gear issue wasn't there on my way home, the next day, it wouldn't hold gear. Truck has 162k miles. Aside from driving hard, regular maintenance is always kept up.
fastpathy35 on Fri Nov 16, 2012 12:49 pm, edited 1 time in total.
