qship96 »
https://forums.nicoclub.com/qship96-u3104.html
Mon Jan 11, 2010 5:21 pm
Why not just perform a simple drain and fill yourself- simple to do, just remove drain plug catch fluid in a drain pan, measure amount drained and refill same amount with new atf through the dipstick.You can do a few of these drain/fills til the fluid looks new. Might consider dropping pan and replacing filter screen if it has never been changed,even though mine was clean when changed at 115,000 miles.
Parked nose up in my driveway{incline} I can get 5.0 quarts out in one drain- which is 45% of total in the system- I now just perform this 1 drain/fill operation every 15,000 miles instead of a full exchange every 30,000 miles.Quick,simple,effective,and only costs $40-50 using top notch synthetic atf
