transmission question
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
lumpy
Car: 1997 200sx w/ sr20det
What is the toughest transmission I can run with my sr20det in my 200? I've done a little research but I haven't come up with too much.
zer099
Car: 200sx GTi-R
A p11/b15 or spec V transmission, though the spec V will require a lot to drop in (ie: p12 bracket and belhousing, spec V spindles, axels, shifter & linkage, and a p12/s15 dual mass fly then you get the option of 240mm or 250mm clutch). 'Course, the odds of finding a p11/b15 transmission are slim to none.
Or you can get a b13 transmission, shotpeen and cryo the stacks, and make sure you get the third gear taken care of before welding her up.
nametakennow
Car: '06 MINI Cooper S
Wrecked B15's/P11s are fairly common, though the LSD trans is a relatively rare option. Still, it's the best choice if you have the patience to find one.
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
